Annonsörer, Prenumeranter och ATV/Quad-Föreningar.
Annonsörer, Prenumeranter och Föreningar
MMOEXP: Path of Exile 2 draws closer, players are deep in theory-crafting mode
Ämne: MMOEXP: Path of Exile 2 draws closer, players are deep in theory-crafting mode (läst 343 gånger)
Ludwighench
Antal inlägg: 3
ATV eller Fyrhjuling?
Ludwighench
7 januari 2026 kl. 08:28:55 »
As the release of
poe2 trade
draws closer, players are deep in theory-crafting mode, strategizing how to create the ultimate build for tackling the game's many challenges. While much of your power in Path of Exile 2 (PoE 2) will come from the revamped passive skill tree and your chosen abilities, support gems offer an additional layer of customization that can take your character to the next level.
These deceptively simple items have the potential to transform your build in profound ways. In this guide, we'll explore how support gems work, and provide a comprehensive list of those discovered so far. Support gems are collectible items scattered across the world of Path of Exile 2 that augment your skills with powerful effects. These enhancements can make your abilities far more potent, providing advantages like increased damage, additional projectiles, or elemental effects. For instance, a support gem might allow your attack to inflict bleed damage or grant freezing capabilities. When used strategically, these gems can drastically elevate your effectiveness in combat.
To use a support gem, simply hover over it to review its effect and then right-click to apply it to a compatible skill you've already learned. Keep in mind that each skill can only utilize one instance of a specific type of support gem. For example, while you can't stack multiple Multiple Projectiles gems on a single skill, you can combine Multiple Projectiles with other effects, such as a freezing or piercing augment.
For those new to the system, the support gem skill menu offers a helpful filter. By checking the box to display only recommended support gems, you can quickly identify optimal combinations for your skills. However, if you're feeling experimental, uncheck the box to explore every available option and discover unique synergies.
While support gems themselves play a vital role in shaping your build,
POE 2 Currency for sale
is equally essential for maximizing their potential. Path of Exile's currency system is famously unique, functioning as a barter economy where every type of currency item serves a specific purpose. Understanding how to acquire and use currency effectively will enable you to tweak and enhance your skills and gear, ensuring you get the most out of your support gems.
995 gäster, 1 användare (0 dolda)
1182
. Flest online någonsin: 12300 (14 januari 2026 kl. 05:35:00)
william
jag har ett problem att när jag har kört snabt ett litet tag kommer ett mis ljud som jag inte vet var det kommer från men när jag låser bak hjulen så försviner det vad kan det vara
william
jag har ett problem att när jag har kört k
2 maj 2023 kl. 10:33:51
Jannethegamer
Tjena någon som har effektljuddämparen till Smc 100, vill köpa men vill först veta skillnaden på den och orginalet.
13 april 2023 kl. 18:49:39
topo1
Jag har en 2009 Cectek Gladiator i Grekland och behöver desperat en ECU. Är det någon på detta forum som vet var jag kan få tag i en?
12 april 2023 kl. 11:21:26
Cookies hjälper oss att ge dig en bättre upplevelse av vår webbsida. Genom att använda vår webbplats godkänner du även användningen av cookies.
OK
Mer info
