CF Moto
Setting of gently
Ämne: Setting of gently (läst 2326 gånger)
Prestone
Antal inlägg: 7
ATV eller Fyrhjuling?
Prestone
Setting of gently
26 januari 2021 kl. 10:55:05 »
Hi.
When i apply throttle very gently from a standstill in any gear on my 520 i can feel something engage with a small jerk just over idle and just before the CV kicks in.
As far as i can see they dont have neither a wet or dry centrifugal clutch so i suppose it is the oneway bearing locking in, but im not sure!
Is this little jerk normal for these ATV’s
Prestone
Antal inlägg: 7
Prestone
SV: Setting of gently
27 januari 2021 kl. 12:27:54 »
Found a cool video that explains the oneway.
So the jerking can only be a small amount of transmission backlash when the CVT spools up.
CF Moto
Setting of gently
866 gäster, 0 användare (0 dolda)
983
