  • Ämne: Hello boys something new for the Suzuki boys.
Författare Ämne: Hello boys something new for the Suzuki boys.  (läst 3400 gånger)
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
« skrivet: 30 november 2014 kl. 00:22:23 »
If you own a AXI Kingquad you can invert the wheels so you get a wider stance some might opt for 2 washer rings. Works like a dream And the only problem is holding on in turns.
Other tip.
If you operate a winch system get a AGM starter battery( 42 amp 900 cycles )
 i took out the normal battery and it works perfectly with all my systems start winch heat lights etc....The battery is on the front frame cargo platform.
(1 person liked this)
Ride the world
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
SV: Hello boys something new for the Suzuki boys.
« Svar #1 skrivet: 30 november 2014 kl. 13:22:28 »
Citat från: Island skrivet 30 november 2014 kl. 00:22:23
Other tip.
* 2014-10-05-1800.jpg (82.12 kB, 1000x562 - visat 269 gånger.)
* 2014-10-05-1812.jpg (112.32 kB, 1000x562 - visat 278 gånger.)
Ride the world
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
« Svar #2 skrivet: 10 december 2014 kl. 23:03:19 »
The Batterybox.
* 2014-12-10-2010.jpg (61.06 kB, 1000x562 - visat 249 gånger.)
* 2014-12-10-2011.jpg (67.24 kB, 1000x562 - visat 240 gånger.)
Ride the world
Utloggad jooko
  • Antal inlägg: 60
  • CF 500
jooko
« Svar #3 skrivet: 10 december 2014 kl. 23:09:20 »
well... if you look at the load point on the hub this would not be any to work on longer terms?
if this was no problem so would suzuki had done this stock,
or iam i wrong?
Adly RS50-08
Yacamy 90cc-05
Smc 250-05
Goes 450-07
access 450-2010
hyosung 450 2009
Suzuki LTZ400 2008
Suzuki lt300F -1999
cectek kingkobra -2009
Linhai 300SE -2008
CFMOTO 500-07
CFMOTO X8 -2014
Goes 625i -13
Polaris 700 -02
Kawasaki bruteforce 750i 2016
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
« Svar #4 skrivet: 12 december 2014 kl. 16:29:42 »
Well the wheel are the stock Suzuki wheels.
And the go on both ways.
I have had no problems with this setup.
And the handling is much better / and i can climb sideways better / and Tip over factor is much less.
Ride the world
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
« Svar #5 skrivet: 12 december 2014 kl. 16:30:20 »
Citat från: Island skrivet 12 december 2014 kl. 16:29:42
And they go on both ways.
Ride the world
2274 gäster, 0 användare (0 dolda)
Flest online idag: 2342. Flest online någonsin: 32151 (16 maj 2026 kl. 09:52:43)
