  • Ämne: Britsmars raptor
Sidor: 1 ... 10 [11] 12 ... 26  Alla   Gå ned
Författare Ämne: Britsmars raptor  (läst 74160 gånger)
Utloggad Britsmar
  • Antal inlägg: 1020
  • idiot
Britsmar
SV: Britsmars raptor
« Svar #120 skrivet: 9 juni 2013 kl. 20:50:56 »
Citat från: cARLBOM skrivet  9 juni 2013 kl. 20:50:20
Det var ingen dålig beställning.. de där måste ju vara en fröjd att få skruva på sen  :)
Den som lever får se  ;)
braaaaaa braaaaaa braaap
Utloggad Britsmar
  • idiot
Britsmar
« Svar #121 skrivet: 9 juni 2013 kl. 20:52:59 »
Citat från: Fenrisulven skrivet  9 juni 2013 kl. 20:43:08
Den ändrar inte mappen i realtid utan den sparar sina ändringar och så får du själv lägga in dem i mappen.
Sen så justerar den ju när du kör, så kör du fis som jag blir ju den ju mappad efter det.
För de pengarna får du ju en riktigt mappning.
Om de nu inte gjort om autotunen det sista året?
"The common misconception is that the auto tune constantly changes your map. What it does is suggest changes which you have to accept. It also only makes 10% adjustments at a time. So you will have to run it for several trips to fine tune your map. The common mistake is people use it with out a switch, so that it is always on when the quad is running. So lets say you start your bike, and lug it through the parking lot to your ridding spot. Its gonna be telling you you need less fuel when, you actually need to downshift to get it in the power band, unfortunately thats not how you ride in the parking lot. Then you get on the trails and your screamin throught the gears, the adjustments are calling for more fuel, probably lots more. Then you lug it back through the parking lot to the truck and laptop to accept your changes, but that ruined your trims. So Im no expert, but it seems like you need the switch to keep it off until your ready to run, find a nice straight run where you can power shift through 5th and shut it off. Accept the trims and do that 10 more times. It will be less if you start with a close map. I also hear most tuners prefer a different a/f ratio, lower than 13, i think. Maybe someone else could chime in on that.
Vilken tur att jag kör som ett svin hela tiden då  ()p :lol:
Ja ne men dåså, blir väl till o beställa den där switchen efter ett par testrundor om det verkar knepigt, går den som en säck potatis när man sotar ur den efter en transportsträcka så får jag väl åtgärda det så.
Utloggad Fenrisulven
  • Lite större, lite bättre!
  • Antal inlägg: 4820
  • Total likes: 118
  • Wargön Finest!
Fenrisulven
« Svar #122 skrivet: 9 juni 2013 kl. 20:54:49 »
Det är rätt! Bevisa mig fel så blir vi glada båda två  :)
Vad hamnar frakten på?
1000R
Utloggad Britsmar
  • idiot
Britsmar
« Svar #123 skrivet: 9 juni 2013 kl. 20:56:42 »
Citat från: Fenrisulven skrivet  9 juni 2013 kl. 20:54:49
240$ om ja minns rätt ifrån mailet, inte gratis precis.
Men o andra sidan ett par kilo som ska packas ner...
Jävla dollarn står högt nu.
« Svar #124 skrivet: 9 juni 2013 kl. 21:08:01 »
Citat från: Raecer skrivet  9 juni 2013 kl. 20:44:54
Perfekt läge föe Hellman o shoppa kolv o kam så ligger du efter igen ()p
Jag ska inte bygga om nåt. Att jag inte hänger på Britsmar vare sig nu eller efter hans trim, har inte så mkt att göra med vad vi har i motorerna. Snarare vad han saknar i skallen.
Nu har jag räknat kugg: 15/36. Och efter 45min hårdlek är jag rätt nöjd med utväxlingen. Visst saknar man lite på landsv men men...
Utloggad cARLBOM
  • Team QRS
  • Moderator
  • Antal inlägg: 1391
  • Total likes: 298
  • Quad Riders Sweden
cARLBOM
« Svar #125 skrivet: 9 juni 2013 kl. 21:10:52 »
En annan har snart 16/31  :D.. förhoppningsvis saknas inget på landsväg då :)
Rockstar 700R Turbo SE - 12
Powercommander 5
Pod300
Autotune
GM 3 bar mapsensor
GT 15 Turbo
Intercooler
650cc spridare
Uppgraderad koppling
HKS SSQV öppen dump
One of a kind
« Svar #126 skrivet: 9 juni 2013 kl. 21:13:39 »
Citat från: cARLBOM skrivet  9 juni 2013 kl. 21:10:52
Nä, men du har ju stängt dörren till gruslek redan vid sänkningen... :nono:
Edit: F*n det är ju 20%!!!!
« Senast ändrad: 9 juni 2013 kl. 21:15:53 av hell-man »
Utloggad cARLBOM
  • Team QRS
  • Moderator
  • Total likes: 298
cARLBOM
« Svar #127 skrivet: 9 juni 2013 kl. 22:08:41 »
Citat från: hell-man skrivet  9 juni 2013 kl. 21:13:39
Powercommander 5
Pod300
Autotune
GM 3 bar mapsensor
GT 15 Turbo
Intercooler
650cc spridare
HKS SSQV öppen dump
One of a kind
Utloggad Britsmar
  • idiot
Britsmar
« Svar #128 skrivet: 9 juni 2013 kl. 23:34:37 »
satte mig ner o läste mig runt på lite forum, då jag såklart efter min .. låt oss kalla det investering... blir lite nyfiken på vad man får ut av den här väldigt planerade (totalt impulsiva) affären.
"I was worried about some of the same things. After talking with Jamie @Fuel Moto and Dynojet tech support they confirmed that the autotune does actually tune on the fly. The trim adjustments shown are actually used when in learning mode. Accepting them just moves the trims to the map and resets them. I saw on my own module that the trims were actually being used on the fly without accepting them as well. For instance at 2% throttle 2500 RPM my base map was set at "3". When looking at the trims I had a trim in that cell of "5". You could see on the right were it shows the actual percent of fuel change was "8" when at that cell. It was using the base map plus the trims. Possibly this is a newer firmware than those that were not getting it to tune on the fly. I stuck the autotune on my drag bike last weekend and it has made a noticeable difference on it, and I have yet to 'accept' any of the trims. "
för att ge lite respons till fenris nitiska inställning!  :whip:
Utloggad Britsmar
  • idiot
Britsmar
« Svar #129 skrivet: 9 juni 2013 kl. 23:50:45 »
och vidare läsning så kommer jag ju efter en herrejösses runda att koppla ur auto-tune enheten och plocka ur syresensorn.
Får väl hyra ut den till alla med pc5 som vill optimera sina mappar  ()p
Med andra ord så är det ju precis vad jag hade tänkt mig, ändå.
Ja menar vad kostar en dag hos nån firma med bromsbänk? knappast mindre än 2000:-, och denna självbänkningen kan man ju göra om o om igen vid vidare modifiering.
Man kunde ju t.om förvisso med extremt mycket längre tidsperspektiv börja med en helt tom mapp, men får man bara grundmappen och kör vidare på den ett par vändor så har jag ju hittils inte hittat nån som säger att det inte funkat.
« Svar #130 skrivet: 10 juni 2013 kl. 06:29:15 »
Jag tänker inte lyssna på detta autotunetrams mer. Min hoj går hur bra som helst med hemmabankad insats full med icalurv helt utan ommappning. Tar jag ur hela skiten så det är helt tomt, ja då går den också hur bra som helst. Dock med lite fler springare men även lite trasiga öron. Jag vet inte om den skulle uppträda så utan autotune-on-the -fly. Men som sagt, den går som en gud iaf. Fenris är bara avundsjuk. Vi slår han på nästa grillkväll.
Utloggad FARLIGMJÖLK
  • Bauce
  • Antal inlägg: 909
  • Legenden
FARLIGMJÖLK
« Svar #131 skrivet: 10 juni 2013 kl. 06:49:48 »
Citat från: hell-man skrivet 10 juni 2013 kl. 06:29:15
Hur.bra.som.helst.... det är ett ganska vitt mått och begrepp. Hur bra är det? Kan du visa med munnen?
Sidor: 1 ... 10 [11] 12 ... 26  Alla   Gå upp
5492 gäster, 0 användare (0 dolda)
Flest online idag: 5950. Flest online någonsin: 32151 (16 maj 2026 kl. 09:52:43)
