  • Ämne: Ventiljustering
Författare Ämne: Ventiljustering  (läst 6111 gånger)
Utloggad 500ho
  • Antal inlägg: 10
500ho
Ventiljustering
« skrivet: 23 augusti 2012 kl. 06:48:06 »
Hej jag ska justera ventilerna på min Sportsman 500 ho -06. Nån som vet vilka mått det ska vara ,och om det är ok att justera vid kall motor,går ej att varmköra för tillfället.Tack på förhand.
Utloggad Jockegubben
  • Antal inlägg: 588
  • Total likes: 18
  • Sportsman 800 Efi -11
Jockegubben
SV: Ventiljustering
« Svar #1 skrivet: 23 augusti 2012 kl. 07:06:31 »
Såhär står det i rephandboken:
MAINTENANCE
7. Verify accurate TDC positioning by observing the “T”
mark aligned with the pointer in the timing inspection hole.
In this position there should be clearance on all valves.
Intake Valve Clearance Adjustment
1. Insert a .006" (.15mm) feeler gauge between end of intake
valve stem and clearance adjuster screw.
2. Using a 10 mm wrench and a screwdriver, loosen adjuster
lock nut and turn adjusting screw until there is a slight drag
on the feeler gauge.
3. Hold adjuster screw and tighten adjuster lock nut securely.
4. Re-check the valve clearance.
5. Repeat adjustment procedure if necessary until clearance is
correct with locknut secured.
6. Repeat this step for the other intake valve.
Exhaust Valve Clearance Adjustment
NOTE: The exhaust valves share a common rocker
arm, and must be adjusted using two feeler gauges.
exhaust valve stem and adjuster screw(s).
2. Loosen locknut(s) and turn adjuster screw(s) until there is
a slight drag on feeler gauge(s). The Valve/Clutch Adjuster
Tool (PA-44689) can be used to adjust the engines valves.
NOTE: Both feeler gauges should remain inserted
during adjustment of each valve.
3. When clearance is correct, hold adjuster screw and tighten
locknut securely.
INTAKE VALVE CLEARANCE
.006” (.15 mm)
EXHAUST VALVE CLEARANCE
.006” (.15 mm)
« Senast ändrad: 23 augusti 2012 kl. 07:09:45 av Jockegubben »
Utloggad 500ho
  • Antal inlägg: 10
500ho
SV: Ventiljustering
« Svar #2 skrivet: 23 augusti 2012 kl. 19:44:43 »
Tackar ! Gick bra de där O0
Utloggad volvo finland
  • Antal inlägg: 9
volvo finland
SV: Ventiljustering
« Svar #3 skrivet: 18 september 2012 kl. 20:07:37 »
Skall ge mig på att kolla upp spelet på ventilerna i min polaris magnum 325.
Behövs det några specialverktyg för ändamålet?vad skall spelet på insugsventil och avgasventil vara?
(Har ett klonkade/tickande ljud från övre delen av motor som kall,låter kanske lite som varm men ytterst lite,ljudet hörs mest på tomgång som kall,varvar man upp lite så är det som om de skulle tystna.
2683 gäster, 0 användare (0 dolda)
Flest online idag: 4258. Flest online någonsin: 32151 (16 maj 2026 kl. 09:52:43)
