  • Ämne: kedja
Författare Ämne: kedja  (läst 2056 gånger)
Utloggad Elmer
  • Antal inlägg: 7
Elmer
kedja
« skrivet: 2 december 2011 kl. 18:45:19 »
har kollat o kollat men begriper inte vart man sträcker kedjan på min predator 500.
 :banghead: ????????????
Utloggad Elmer
  • Antal inlägg: 7
Elmer
SV: kedja
« Svar #1 skrivet: 4 december 2011 kl. 22:18:56 »
36 st som har läst, och ingen som vet?  ':)
Utloggad Jockegubben
  • Antal inlägg: 588
  • Total likes: 18
  • Sportsman 800 Efi -11
Jockegubben
SV: kedja
« Svar #2 skrivet: 4 december 2011 kl. 22:51:55 »
Äger ingen quad men jag använde google.se, skrev "How do you tighten the chain on a polaris predator 500?". Första länken som kom upp stod det exakt hur man skall göra.
Såhär gör du:
"Do not put the bike on a stand or anything. Leave it on the ground. Start by loosening the two bolts at the rear of the swingarm. They are 14mm nuts. On the sprocket side of the swingarm you can see notches in the carrier. Jam some kind of metal rod or a an allen key or something into one of the holes, through the sprocket. You then have to roll the quad either forward or backward so the rod is against the sprocket and you're turning the carrier inside the swingarm. Depending on where your carrier is now you may have to push the quad forward or backwards. There are several slots in the carrier so you can easily move the rod and continue to roll the quad. Your chain will eventually get tighter and you can take out the rod and tighten the bolts on the back of the swingarm. Sounds complicated but it's pretty simple once you get down to it. You'll understand once you get going"
Utloggad Elmer
  • Antal inlägg: 7
Elmer
SV: kedja
« Svar #3 skrivet: 6 december 2011 kl. 22:19:25 »
Tack för svaret    ()p
  • Ämne: kedja
1061 gäster, 0 användare (0 dolda)
