  • Ämne: Olja kingquad
Författare Ämne: Olja kingquad  (läst 13428 gånger)
Utloggad negertwin
  • Antal inlägg: 25
negertwin
Olja kingquad
« skrivet: 17 november 2011 kl. 15:02:09 »
Hur mycke olja ska det va i motorn på en kingquad 750?
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
SV: Olja kingquad
« Svar #1 skrivet: 17 november 2011 kl. 15:11:27 »
almost 4 liter
Advise.
My servis book says less
It has not been my experiance i did run down the motor this summer due to lack of oil
I had it done like the book says .
The result i did blow the engine but to my releif the cylinder is so strong and well made i just needed the pistons and stuff to get it rolling again.
Go with the oil meter in the motor it will say almost 4 liter
I go with 4 liter even if it a little more then the meater says.
Be shure to fill the oil filter before innstaling it. you will get bubbles until full.and be shure to take the older rubber of the engine that comes with the filter and use oil on the rubber it will seal the filter to the engine.
Advise nummber 2
Since i do a lot of angle rides upp and down hills the engine will burn oil faster then regular.
look at the oil lever every 500 km just to be on the safe side.
McFury.
Ride the world
Utloggad negertwin
  • Antal inlägg: 25
negertwin
SV: Olja kingquad
« Svar #2 skrivet: 18 november 2011 kl. 07:30:43 »
Tack för tipsen:)
Utloggad siles
  • Antal inlägg: 137
siles
SV: Olja kingquad
« Svar #3 skrivet: 18 november 2011 kl. 19:54:21 »
Citat från: Island skrivet 17 november 2011 kl. 15:11:27
almost 4 liter
Advise.
Advise nummber 2
McFury.
4liter!!?? Aldrig, det är 2,5 liter MED filterbyte
MvH S
KingQuad 700 -06
Unifilter
BigGun EFIbox
BigGun Dämpare
Gul EPI
17.8g Vikter
1.75mm shims
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
SV: Olja kingquad
« Svar #4 skrivet: 18 november 2011 kl. 20:37:47 »
Hummmmm.
If you drain the motor in the bottom plug you drain the engine and Gear oil
motor needs 2.5 and gears need the rest.
Not just 2.5 l
Do the math.
Ride the world
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
SV: Olja kingquad
« Svar #5 skrivet: 18 november 2011 kl. 21:07:33 »
No thank you ?
McFury.
Ride the world
Utloggad siles
  • Antal inlägg: 137
siles
SV: Olja kingquad
« Svar #6 skrivet: 18 november 2011 kl. 21:55:00 »
Citat från: Island skrivet 18 november 2011 kl. 21:07:33
No thank you ?
McFury.
Nope, you wont get a thank you since you are wrong.
 2.5 liters for a oilchange with the filter.
Its only around 4 liters if he is doing a complete overhaul, which i doubt he is doing.
Your welcome. ;)
KingQuad 700 -06
Unifilter
BigGun EFIbox
BigGun Dämpare
Gul EPI
17.8g Vikter
1.75mm shims
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
SV: Olja kingquad
« Svar #7 skrivet: 18 november 2011 kl. 22:11:31 »
With 2.5 l
Is there oil on the oil stick on your Quad ?
Not on my Quad it needs 3.8 liter
If you use just 2.5 l
WHERE  :djump: :djump: :djump:   do you oil the gears ? And how much oil there. :D
You do have gear on your Kingquad right.
McFury
Ride the world
Utloggad Island
  • McFury
  • Antal inlägg: 185
  • McFury
Island
SV: Olja kingquad
« Svar #8 skrivet: 18 november 2011 kl. 22:58:40 »
I will tell you why they say 2.5l
if you take the oil filter off and drain.
You would need to refill with 2.5 liter of oil.
If you drain the bike from the bottom.
You need´s a shy of 4 liter.
Or just go with the dip stick on your bike.
The manual is a bit fuck´t  up.
Ride the world
Utloggad rmkungen
  • KQ 700
  • Antal inlägg: 271
  • FTP
rmkungen
SV: Olja kingquad
« Svar #9 skrivet: 2 december 2011 kl. 11:18:53 »
ja men tömm i 4 liter du som islänningen säger, så kan ju han betala haveriet sen :)
töm ur motorn och töm i tills du har olja på stickan, du ska inte skruva ner den när du kollar utan bara stoppa ner den, enklast att kolla på de viset
KQ700
hasplåtar
warn winch RT25
fulldubbad tatou bandsats
kenda bearclaw på org breddade fälgar
kenda executioner på ss112 fälgar
v-kitt
xenon överallt
handtagsvärme
powermad
In å gilla oss på FB
Sök "Team MG&SV Maniacs"
Utloggad negertwin
  • Antal inlägg: 25
negertwin
SV: Olja kingquad
« Svar #10 skrivet: 5 januari 2012 kl. 13:02:01 »
Tack för alla tips :) ja fick i 3,8 l då va det perfekt på Stickan
Utloggad rmkungen
  • KQ 700
  • Antal inlägg: 271
  • FTP
rmkungen
SV: Olja kingquad
« Svar #11 skrivet: 10 januari 2012 kl. 05:33:59 »
har aldrig fått i så mycke när jag har bytt olja, och jag har nog bytt 8ggr på 300 mil,
KQ700
hasplåtar
warn winch RT25
v-kitt
xenon överallt
handtagsvärme
powermad
1836 gäster, 0 användare (0 dolda)
