Allmän diskussion
Allroad/Offroad
AIR Suspension Suzuki.
Ämne: AIR Suspension Suzuki. (läst 5547 gånger)
Island
McFury
ATV Entusiast
Antal inlägg: 185
Total likes: 3
McFury
Island
10 november 2011 kl. 21:49:22 »
Hello Boys.
I have been looking at air suspension for my Kingquad.
looks nice and comfy.
Since i know many of you own a Kinquad how much raise should i opt for from the standard height on the suzuki so i dont need to change the geometry in the drives.
Any thoughts.
Senast ändrad: 11 november 2011 kl. 20:39:30 av Island
Ride the world
Viktor_EX
Antal inlägg: 36
Total likes: 2
Kingquad 700 Gamax 600
Viktor_EX
SV: AIR Suspension Suzuki.
29 oktober 2014 kl. 10:21:32 »
i use for my mountain tours in Kingquad or Gamax Protlum shock absorber. It is very komfortable, adjusted as very progressiv. You drive slowly, suspension are soft, you drive agresiv, suspension will be strong.
i can adjust on spring, atv is little bit lower, atv is more stable, is little bit deeper, aarms can better copy terrain. it great feeling vs original. My description = is like Beatle Tank, you swimm over terrain and you can perfect controll it. original can you vergot, it is toy. in every hohl you crash on the end of shock. Protlum as trade is Czech and have many experience in autocross, buggycross and this racingtechnology is in shocks for ATV. All construction is strong and heavy. Lifetime very very long. Shocks can be repaired. But since 2006 in romania mountains i dont need repairing... after all very heavy terrain, 80-100kg on atv + 100kg me. All my ATV have this suspension.
.... Regards Vlasta (speek german or english)
ATV Adventure Tours - Quadprofi.cz
Allmän diskussion
Allroad/Offroad
4813 gäster, 0 användare (0 dolda)
5186
