Allmän diskussion
The 4x4 Drive syndrome
Ämne: The 4x4 Drive syndrome (läst 1792 gånger)
Island
McFury
ATV Entusiast
Antal inlägg: 185
Total likes: 3
McFury
Island
1 november 2011 kl. 13:23:37 »
Hejsan.
i dont want to drop a bomb.
But some Atv have drive problems i mean this when you ad to them Snowbelts or Trax´s
The front and rear gear ratio is not the same.
So when in 4x4 the front ratio pulls more then the back ratio.
This is a problem for the drive on the atv since the pull is much more heavy on belts then tires.
Most of you owner know this if you have been stuck in mudd or snow.
This small list is just for show and done by a trax´x maker that has done the correction to the front drive so the trax pull the same.
Good to know if you plan to get trax´s
All my best McFury.
The List.
Ride the world
Antal inlägg: 3446
Total likes: 3
Från: 08
SV: The 4x4 Drive syndrome
2 november 2011 kl. 23:22:15 »
Tatous have diffrent drive wheels/drive sprockets, from 15-18 teeth.
What brands have diffrent ratio?
Stöd Svenska ATV föreningen du med, bli medlem NU! Klicka där ->
www.satvf.se
Island
McFury
ATV Entusiast
Antal inlägg: 185
Total likes: 3
McFury
Island
2 november 2011 kl. 23:36:22 »
Its not the trax´s
Its the atv ´s gear ratio thats the problem.
Front and rear tires dont pull the same ratio on some ATV.
My best McFury.
Ride the world
Allmän diskussion
1988 gäster, 0 användare (0 dolda)
2238
