Kazuma/Viarelli/Titan
Olje funderingar
Ämne: Olje funderingar (läst 2840 gånger)
Busan
Hobbyåkare
ATV Entusiast
Antal inlägg: 146
Busan
Olje funderingar
24 mars 2011 kl. 13:49:03 »
Har en kompis som har en Kazuma 500. Vilken olja ska han ha i motorn? Ska han ha benämningen Jaso?
Busan
BE-10
Hasplåt
Handtagsvärmare
Sadelvärmare
Voltmätare
Cirusvirus
Antal inlägg: 5
Cirusvirus
SV: Olje funderingar
24 mars 2011 kl. 20:59:23 »
Hittade lite info på kazuma.com
bifogar en länk:
http://www.kazuma.com/Buy/pic/200806/20/20086201915928.pdf
Please do the following services before you (the dealer) selling or (the internet buyer)
assembling/riding the bike.
CLEAN GAS TANK – It has been brought to our attention that there may be dirt inside the gas tank
(like black pepper) which will pill off slowly after touching the gas. The dirt will block the fuel filter and cut
off engine. Please fill up the gas tank over a week, and drain the gas until you see no dirt before you do a
long drive trip.
DRAIN ENGINE OIL – Once you assembled the unit (before driving the unit), you must drain all the
engine oil in the unit and replace the oil with 10W-30 or 0W-40 synthetic (preferred). The shipping oil
(15W-40) could blow out the oil filter.
ERROR in OWNER’S MANUAL
Please use the following recommendations instead of the one on the owner’s manual.
Engine oil: 10W-30 or 0W-40 synthetic (preferred)
(Do not use 15W-40 or any thicker oil than 10W-30)
Spark plug: K6RTC (NGK:R BCPR7ES or R FR5AP-10)
Olje funderingar
1981 gäster, 0 användare (0 dolda)
2460
