  • Ämne: Tips på lite mer fart i era kawwor med insprut
Författare Ämne: Tips på lite mer fart i era kawwor med insprut  (läst 4923 gånger)
Utloggad wasteland
  • Mud slut, hitting every hole !
  • Antal inlägg: 471
  • ASRD engineering solusions
wasteland
« skrivet: 14 mars 2010 kl. 20:21:19 »
Här kommer ett litet tips på en enkel mod för att få lite mer kräm i era maskiner, ska vara för insprutnings maskinerna enligt utsago.
Kan va bra att kunna skaplig engelska dock..
http://www.mudinmyblood.net/forum/showthread.php?t=741&highlight=effect+engine
Dont like my driving? E-mail me at: EatShit@GoFuckyourself.nu
Utloggad wasteland
  • Antal inlägg: 471
wasteland
SV: Tips på lite mer fart i era kawwor med insprut
« Svar #1 skrivet: 14 mars 2010 kl. 20:22:46 »
Om man inte har inlogg, kan man läsa texten här, dock inga bilder!
Ever since the introduction of the very first Vtwin Kawi, the 650 prairie, every model that's been released has had a low-speed timing retard. This is done by Kawasaki to protect their liability. Basically, the KILL the launch of their quads below 10 mph. The good news is that EVERY MODEL that they've ever released use a very simple method to do this. They "read" the speed sensor. The speed sensor works as an electromagnet. A "high point" passes near the sensor on the gear that it is facing. This produces a electric pulse. The faster the bike goes, the more often the pulse is read by the ECU. Once the ECU interprets that the pulses are going above 10mph, it "fixes" the timing, and the bike runs much much harder and more optimally. This is essentially a "sin" wave.
Enter the first generation of "holeshot module". Somewhere along the line, someone figured out that IF you "trick" the CDI/ECU into thinking it's above 10 mph, it will give full power(and timing) to the bike at all times. The next step was designing a product that would do this. Basically, what a holeshot module does, is send a 10+ mph signal to the CDI/ECU at all times. It takes 12v and modifies it into a "wave", which is essentially the function of a power inverter, only much simpler in this case. Basically, it completely replaces the signal of the speed sensor with it's own signal to accomplish the purpose of removing our timing retard and thus our LAG.
Ok, now the part that everyone is wanting to know. HOW do we make this work on our EFI bike? Well, it's simple really. Long story short, an EFI bike uses the same CDI ignition as other bikes, just by encorporating it into an ECU. It's inputs and outputs are all the same. So, you do this THE SAME way you did before! It's done using the same modules! It's even the same color wire! The only thing that is any different is the location that the wire enters the ECU. Where is this wire? Well, it's the FRONTMOST pink wire on the ECU. You have to cut this wire, and buttsplice in the holeshot module to the ECU. You leave the end coming from the sensor open. From there, you can wire the + and - to any place on the harness that is appropriate to get power when the bike is on, but not when it's off. Generally, it's easiest to go to the ignition circuit. Regardless, here are a few pics. The first is of the speed sensor itself(notice the pink wire). The second shows a rather pitiful version of where the pink wire is located, and how we tied into it.
What can you expect to gain from this? Abrupt/insane power out of the hole. This mod can be done all by itself, and requires NO other changes to work and provide a VERY LARGE power improvement at holeshot. After 10mph, it will not effect the quad in any way. However, if larger injectors are added along with a PC3 and a tunejob, it'll be easily FASTER than your buddy's equally modded carbed brute, in EVERY part of the powerband, with even better throttle response than he has. All things equal, these 3 mods will make the bike EVERY BIT as fast as an equally modified Outlander 800 in 300'.
Utloggad matte_k_
  • Antal inlägg: 75
matte_k_
« Svar #2 skrivet: 28 mars 2010 kl. 12:02:43 »
Någon som testat o kan bekräfta??
Utloggad NeoBoll
  • Antal inlägg: 202
  • YFZ450R
NeoBoll
« Svar #3 skrivet: 28 mars 2010 kl. 12:55:40 »
Ja, det ska tydligen funka, iallafall säger dom det på alla forum i usa,
jag ska beställa en holeshot module lite senare och testa, kostar ca 100 usd.
Eller så skaffar man en copperhead där funktionen är inbyggd.
Utloggad wasteland
  • Antal inlägg: 471
wasteland
« Svar #4 skrivet: 28 mars 2010 kl. 19:44:49 »
Citat från: NeoBoll skrivet 28 mars 2010 kl. 12:55:40
Jasså, är det så ! Bra att veta..
Utloggad siles
  • Antal inlägg: 137
siles
« Svar #5 skrivet: 29 mars 2010 kl. 20:31:29 »
Har en polare som har sån på sin 05 så det funkar på förgasar brute med ;)
KingQuad 700 -06
Unifilter
BigGun EFIbox
BigGun Dämpare
Gul EPI
17.8g Vikter
1.75mm shims
Utloggad wasteland
  • Antal inlägg: 471
wasteland
« Svar #6 skrivet: 29 mars 2010 kl. 20:42:35 »
Jag har sån på min med.. dock vet ja inte hur den är utan  ^-^
Utloggad WoX
  • Framför 2 Jobb
  • Antal inlägg: 90
  • Second place is the first looser
WoX
« Svar #7 skrivet: 14 maj 2010 kl. 22:29:01 »
Citat från: siles skrivet 29 mars 2010 kl. 20:31:29
Jag kör med box och system på min brute 2009;a och har mappat den i bänk och inte går den sämmare iaf   :djump:
Polaris Predator 500cc 2005
Polaris Outlaw 500cc  2007- vägreg
Kawa  BruteForce - 750 - 2008  WoX Edit
Kawa  BruteForce - 750 - 2009 WoX Edit 2
Can-Am 800R Xmr - 2011 Såld
Can-Am Outlander 800 Xtp 2011  = STULEN
Can-Am Renegade Xxc 800  -2010
Can-Am Renegade Xxc 1000 2012
Polaris Ace  570 Sp WoX Edition -2015
Can-Am Outlander Xtp 1000 -2015 ()p
Can-Am Maverick 1000R -2015  ()p
2092 gäster, 0 användare (0 dolda)
Flest online idag: 2374. Flest online någonsin: 32151 (16 maj 2026 kl. 09:52:43)
