  • Körteknik »
  • Ämne: Åka bakhjul
Sidor: 1 [2] 3  Alla   Gå ned
Författare Ämne: Åka bakhjul  (läst 17470 gånger)
Utloggad Benny
  • Antal inlägg: 158
Benny
Åka bakhjul
« Svar #12 skrivet: 21 april 2005 kl. 20:20:48 »
Har  e sketa svårt nöjjer mig me att stegra me moppen eller nåt annat typ gräsklipare
 :D  :D
vh Benny// Honda trx 450 s foreman 98
Utloggad kenta
  • Antal inlägg: 564
kenta
kenta
« Svar #13 skrivet: 23 april 2005 kl. 15:45:13 »
Åkte på bakhjulen idag i ältagropen,åk dit om ni inte får upp framhjulen
AWASAKI 750 Brute Force -06,Silver Ltd Edit,Gatreg,Gatdäck på ITP,Trg på Orig,Wileyco Helsystem,
,ITP Mud Lite XL trgdäck,Spacers.Winch, 5 x-ljus fram, 1 backljus.Dubbade originaldäck.
LedThumb
LedThumb
Åka bakhjul
« Svar #14 skrivet: 27 juni 2005 kl. 11:42:51 »
Liten info... Lägg märke till att Honda FourTrax 300EX är i princip en Adly 300 fast Adlyn har lite mer kraft...
Detta är saxat ur Dirt Wheels Magazine:
How To Wheelie-Mar'00
(11/6/2000)
We don't quite know what it is about wheelies, but they sure are fun to do on an ATV. And they?re not just for entertainment either. Out on the trail the ability to pop the front end a couple feet off the ground will make you a better, more efficient (and in some cases a cleaner) rider.
Of course some quads are easier to wheelie than others. Much of it has to do with the type of transmission and clutch used, while in others the so-called "balance" of the machine?its ability to be ridden at a certain angle for a length of time?factors into the equation as well. Fortunately, all quads made today have a rear grabbar that allows the rider to "overcook" it a bit without tipping all the way over backwards, eliminating most of the fear factor when practicing wheelies for the first time.
Following are step-by-step techniques for wheelies on manual-clutched, and auto-clutched four-wheelers. We?ve also included a list of what we feel are the top 10 wheelie quads made today.
Once you have the front end up in the air, the next step is to find the "balance point" of the machine. On most quads it?s the angle pictured here, a point where the quad feels like it can balance on the two rear tires without falling forward or rearward, with you staying put on the back of the seat. Keep it in this position by using both the clutch and the throttle to control the power, and taps on the rear brake to push the front end down slightly if you feel like you?re tipping over backwards. The trick is to make all of these moves quickly and smoothly so the front end doesn?t drop to the ground and you don?t go the other way and drag the grabbar. Once you can keep the quad at the balance point, you can theoretically wheelie forever. Expert wheelie guys can even shift through the gears.
To start your wheelie with a sport or hi-performance quad, pull in the clutch, shift into first or second, rev it up to around 3/4 throttle, sit back, and pop the clutch. Once you start getting close to the balance point, you can use your arms to slightly push or the pull the front end to the right spot, as well as using the clutch and the throttle. If your quad is always pulling to the right or the left when you?re doing a wheelie, one of your tires has lower air pressure than the other.
Auto-clutch quads are little harder to wheelie, but once you get them up, they?re generally easy to balance since the powerband of their engines is so smooth. To get an auto-clutch quad into a wheelie, depress the foot shifter down but don?t let it pop up yet. Then give the quad about half thottle, let the foot shifter pop up into first and at the same time pull up on the bars. Get your weight back, find the balance point, and off you go.
The wheelie-out-of-a-cor­ner is a stylish move you can use to impress the girls. Simply throw the quad into a slide and just as you?re getting forward momentum, pop the clutch, sit back on the seat, and hang on! Top guys can sometimes do one-wheeled wheelies for a moment, but that maneuver will eventually catch up to you. It is best done in the sand so you don?t scrape yourself or your quad up too much.
DIRT WHEELS TOP 10 WHEELIE QUADS
1. Honda FourTrax 400EX
2. Honda FourTrax 300EX
3. Yamaha Blaster 200
4. Kawasaki Mojave 250
5. Honda Recon 250
6. Suzuki QuadSport LT80
7. Yamaha Banshee 350
8. Yamaha Warrior 350
9. Kawasaki Lakota 300
10. Kawasaki Bayou 220
Utloggad Tenacious_Dboy
  • Antal inlägg: 74
  • En motor galen kille på 30 år i från Eksjö
Tenacious_Dboy
bakhjulen
« Svar #15 skrivet: 14 september 2006 kl. 19:50:16 »
ja nu har jag äntligen köpt mig en Suzuki Ltr 450 så nu är det bara hitta mod och balans..och vill gärna lära mig med att åka och pumpa lite med bakbromsen så man kan åka sakta och med cool lutning :) men man får väl fixa sig nåt stöd så man slipper slå runt första gångerna :S
Tjena jag är en grabb på 30 år och är bosatt i Eksjö..en lite stad som ligger i Småland..har nu gått med i Vetlanda Atv Offroad Mud Ratz, så nu ska min Cf moto X7:a byggas om lite med tiden så den blir mer optimal, då jag tyvärr inte kan finansiera en Can Am som jag väldigt gärna skulle vilja :)
Utloggad Hallbo
  • Antal inlägg: 297
Hallbo
Åka bakhjul
« Svar #16 skrivet: 13 oktober 2006 kl. 19:27:17 »
Är själv jävligt rookie med åkandet i allmänhet men nyss här på kvällen var jag ute och provade på och slanga lite för första gången och är jävligt imponerad av hur bra det gick, kom nästan 250m som längst.
MEN, jag körde knästående, petade i 4an på raptorn, när man fick upp lite varv tröck jag tummen i bott och lutade mej bakåt, fick upp en fin vinkel och i den får man fippla lite med gasen för att hålla balansen, felet är att jag inte vågar gå längre bak så att när jag inte har mer gas att ge så kommer jag ner på jorden igen.
Lite taffligt kanske men jag känner mej jäkligt tuff ändå.
Måste antingen lära mej växla på slangen eller våga lite mer.
Roligt var det iaf.
m jag nånsin ser en leende joggare ska jag överväga saken.
Raptor 700R - 06 vit (var iaf)
Utloggad Jocke72
  • Antal inlägg: 985
Jocke72
Åka bakhjul
« Svar #17 skrivet: 14 oktober 2006 kl. 00:30:42 »
Citat från: "Hallbo"
Roligt var det iaf.
Gör du 250meters powerwheelie?! Det var inte dåligt...
Hoj var inga problem men Quad är värre. Har börjat nöta lite med hustruns GasGas, men jag har blivit så förbannat feg sen min olycka. GG:n verkar inte vara den bäst lämpade heller, om man tittar på Kjelle och hans LTZ... GG:n är så förbenat framtung avsaknaden av bakbroms och bristande teknik hjälper inte heller...  :roll:
/J
33 - Boive-Racing.com
Sponsrad av:
Denada
Verktygsboden
Utloggad Hallbo
  • Antal inlägg: 297
Hallbo
Åka bakhjul
« Svar #18 skrivet: 15 oktober 2006 kl. 17:57:20 »
Doh, såg det nu, en nolla kom med också, 25 ska det vara. Flåt
Im no superman.
Och enda anledingen att jag kommer så långt är att det går så fort innan jag drar upp den, det hela är ju över på några sekunder.
Utloggad Hoogan
  • Antal inlägg: 94
Hoogan
« Svar #19 skrivet: 19 oktober 2006 kl. 21:52:04 »
Ok, har nu monterat en grab-bar så kom med trixen för jag bara måste köra på bakhjulen.
/ h
amaha Raptor 700R 2007
HMF Racekit
Dobeck TFI
Custom map
Qmax Race nerfbars
Bullbar
Skidplate fram
Skidplate bak
Grab-bar
Utloggad Hallbo
  • Antal inlägg: 297
Hallbo
Åka bakhjul
« Svar #20 skrivet: 29 oktober 2006 kl. 14:49:16 »
Åk inte bakslang med ojämt luftryck. Då bär det iväg åt h-vete
Utloggad Atv Roslagen
  • Antal inlägg: 110
Atv Roslagen
SV: Åka bakhjul
« Svar #21 skrivet: 19 november 2010 kl. 22:27:36 »
Nytt rekord i trådlyft??
Denna tråd lyfter fram ett problem som jag har, och det är att jag bara kan köra på fyra hjul. Kanske lika bra det egentligen.. :-X
Utloggad Pson™
  • Egenhändigt utnämd Expert
  • Antal inlägg: 534
  • Dalarna-Falun
Pson™
SV: Åka bakhjul
« Svar #22 skrivet: 19 november 2010 kl. 22:29:21 »
Lågväxel å rycka lite i styret.. Då ska det gå.. ()p
Can Am Renegade 800R Xxc
      Styrhöjare
      Bighorn 27"
Utloggad wheel1
  • Antal inlägg: 50
  • Kör så det ryker! O ryker det inte, så kör ändå...
wheel1
SV: Åka bakhjul
« Svar #23 skrivet: 20 november 2010 kl. 16:42:04 »
Har hört att det är nån slags lågvarvsstrypning på min maskin (För att skydda de amerikanska försäkringsbolagen från bakåtvolter) :knupple:
Vet inte om det är därför jag har svårt att få nåt ordentligt lyft på min Kawa Brute Force, eller om det bara är jag som har svårt att hitta tillräckligt fäste (Eller om jag är för mesig   :dntknow: )?
Ja ja..
Det borde lösa sig när jag så smånigom får på ett Muzzy och ett lämpligt trimchip.
Kawa KVF750i "Brute" - Dirt Devil II 28"
Sidor: 1 [2] 3  Alla   Gå upp
  • Körteknik »
  • Ämne: Åka bakhjul
2409 gäster, 0 användare (0 dolda)
