  • Ämne: hyosung och raptor i grusgrop
Sidor: 1 2 [3]  Alla   Gå ned
Författare Ämne: hyosung och raptor i grusgrop  (läst 5437 gånger)
Utloggad banarne71
  • Antal inlägg: 168
banarne71
« Svar #24 skrivet: 14 juli 2007 kl. 19:48:14 »
Du behöver inte köra in motorn som ett fruntimmer. Det senaste är att man ska värma motorn för att sedan belasta den och varva en hel del på växel 2, 3, 4, 5....
mer finns på denna länk:
http://www.mototuneusa.com/break_in_secrets.htm
Ett utdrag från denna sida:
On the Street:Warm the engine up completely:
Because of the wind resistance, you don't need to use higher gears like you would on a dyno machine. The main thing is to load the engine by opening the throttle hard in 2nd, 3rd and 4th gear.
Realistically, you won't be able to do full throttle runs even in 2nd gear on most bikes without exceeding 65 mph / 104 kph. The best method is to alternate between short bursts of hard acceleration and deceleration. You don't have to go over 65 mph / 104 kph to properly load the rings. Also, make sure that you're not being followed by another bike or car when you decelerate, most drivers won't expect that you'll suddenly slow down, and we don't want
anyone to get hit from behind !!
The biggest problem with breaking your engine in on the street (besides police) is if you ride the bike on the freeway (too little throttle = not enough pressure on the rings) or if you get stuck in slow city traffic. For the first 200 miles or so, get out into the country where you can vary the speed more
and run it through the gears !
Be Safe On The Street !
Watch your speed ! When you're not used to the handling of a new vehicle, you should accelerate only on the straightaways, then slow down extra early for the turns. Remember that both hard acceleration and hard engine braking (deceleration) are equally important during the break in process.
Lycka till med en snygg hoj! :D
MVH Mr Banarne
dly 300 -07
Duncan fat Boy 4
Spacers fram & bak
Aluminiumfälgar Q-max med vägdäck 255X60X10 bak, 10" fram
Ombestyckad förgasare
Öppet filter
Svart
Sidor: 1 2 [3]  Alla   Gå upp
3103 gäster, 0 användare (0 dolda)
