  • Ämne: MMOexp WoW Forever DPS Tier List: Which Class Deals the Most Damage?
Författare Ämne: MMOexp WoW Forever DPS Tier List: Which Class Deals the Most Damage?  (läst 4 gånger)
Utloggad Lilidala
  • Antal inlägg: 4
Lilidala
« skrivet: Idag kl. 10:28:22 »
Summary
The latest WoW Forever hotfixes have reshaped the level 60 DPS meta. Survival Hunter leads the rankings, followed by Fury Warrior and Marksmanship Hunter. Meanwhile, Paladin, Druid, Mage, and Hunter changes have shifted several specs' performance. This WoW Forever DPS Tier List 2026 ranks all 20 DPS specs, helping players choose a main, plan respecs, and spend wow gold more efficiently. Shop at MMOexp and use code "candy" for 8% off.
1. WoW Forever DPS Tier List: S-Tier Winners
Survival Hunter (20 points) takes first place, earning five S votes and hitting 100% in all four damage simulations. Fury Warrior (19) follows with strong sustained damage, while Marksmanship Hunter (18) delivers excellent results across most tests.
However, hunters face important limitations. The October 28 hotfix reduced Aspect of the Hawk and Trueshot Aura, costing ranged hunters approximately 0.5% damage. Since the October 15 patch, Auto Shot also requires standing still for 0.5 seconds. Movement management is therefore crucial.
2. A Tier: Strong DPS Choices
Demonology Warlock (17) narrowly misses S tier despite ranking second in the standard single-target simulation.
Beast Mastery Hunter, Fire Mage, Arcane Mage, and Arms Warrior each score 15 points. Retribution Paladin reaches 14 following its October 30 talent-tree rebuild.
Shadow Priest, Affliction Warlock, and Destruction Warlock finish with 13 points. All three sit dangerously close to B tier.
Fire Mage benefits from instant Fire Blast and damage-over-time effects during movement. Arcane Mage reaches 69.8% of the leading spec in the standard simulation, making its A-tier position particularly fragile.
3. B Tier: Situational Damage Dealers
Combat Rogue, Enhancement Shaman, and Feral Druid score 10 points. Assassination Rogue and Frost Mage earn nine, while Balance Druid barely secures B tier with eight.
Enhancement Shaman and Feral Druid are comfortable choices for mobile encounters. Enhancement performs particularly well against multiple targets.
Feral lost Berserk in the latest hotfix, replaced by Predatory Discipline. Balance Druid gained a buff through Naturalist, providing up to 10% additional damage.
Frost Mage struggles in longer multi-target fights. Ice Lance now deals 300% damage against frozen targets with an eight-second cooldown, but its ranking falls from 15th to 19th in the five-minute three-target simulation.
4. C Tier: Specs That Need Caution
Subtlety Rogue scores six points, while Elemental Shaman finishes with four.
Subtlety struggles with area damage, ranking last against three targets in both fight durations. Elemental Shaman also performs poorly against single targets, reaching approximately 50% of the leading spec's damage.
Although Improved Ghost Wolf helps Elemental mobility, players cannot cast spells while transformed.
5. How to Choose the Best WoW Forever DPS Spec
For reliable damage, choose Survival Hunter, Fury Warrior, or Marksmanship Hunter. Beast Mastery, Arms, Enhancement, and Demonology offer attractive multi-target potential.
For movement-heavy encounters, consider Enhancement, Feral, Shadow, or Affliction and Destruction Warlock. Balance, Frost, and Elemental require more careful positioning.
Remember that four of the five ranking votes come from stationary-target simulations. The results are most useful for Patchwerk-style encounters, not definitive predictions for every raid.
Blizzard has expressed an intention for Warriors to become cleave specialists and Rogues to excel in stationary single-target combat. Future hotfixes could therefore change these rankings again.
Final Verdict
The WoW Forever DPS Tier List 2026 makes Survival Hunter the safest overall damage pick, with Fury Warrior and Marksmanship Hunter close behind. Nevertheless, player execution, encounter mechanics, and movement can matter more than a single tier score. Treat these rankings as a starting point rather than a permanent meta.
If you want to spend less time farming and more time optimizing your build, MMOexp offers an option to buy wow gold  for respecs, consumables, and gear. Use code "candy" for 8% off.
2690 gäster, 0 användare (0 dolda)
