  • Körteknik »
  • Ämne: MMOexp ARC Raiders: How to Identify Lootable Androids
Författare Ämne: MMOexp ARC Raiders: How to Identify Lootable Androids  (läst 3 gånger)
Utloggad Stellaol
  • Antal inlägg: 3
Stellaol
« skrivet: Idag kl. 04:53:40 »
Some androids spawn in visually noisy areas with debris, crates, or pipes. Their humanoid silhouettes can blend into ARCR Coins the environment.
Near lower-level machinery or control terminals
Mechanical sections of the map, especially those resembling maintenance floors, frequently house android models.
Even when exploring these high-probability areas, spawn rates vary dramatically between sessions-so you may find several androids in one run and none in the next.
Stella Montis is full of inactive android models, but most of them cannot be looted. They function as environmental props and will not progress the quest.
To avoid wasting time, watch for:
1. Interaction Icons
A lootable android will display a small interaction prompt or icon above its body when you're close enough. If you see no icon, it's a static, non-quest variant.
2. Slight Highlight or Glow
Some androids give off a subtle outline when you're within a few meters, similar to other interactable objects in the game.
3. Contextual Clues
Lootable androids are often positioned in a more deliberate pose-lying flat on the ground, seated upright, or placed against machinery-rather than slumped in irregular angles.
Because interactable androids are visually identical to the non-lootable ones until you get close, you'll want to carefully check each one you encounter. Don't assume an Android isn't lootable just because it looks like the others.
The Good News and the Bad News
The bad news is that the randomized Android spawn system means you can't memorize three fixed locations and speed-run the quest. Luck plays a role, and you may find yourself exploring for several minutes before encountering your first lootable android.
But there's good news, too: lootable androids are not especially rare once you understand Stella Montis' layout. With methodical exploration-checking corners, back rooms, and halls you might normally ignore-you will almost always find enough androids to finish the quest within one or two runs.
Treat this quest as a scavenger hunt rather than a beeline objective. The slower, the more thorough you are, the faster you'll finish it.
Completing the Quest
After looting your third Android, you'll automatically complete the objective for "In My Image." With that done, your next step is returning to Lance in Speranza-but first, you'll need to make it out alive.
Extracting Safely
Stella Montis includes multiple extraction points, but the route to them can be dangerous:
Shredder units roam many sections of the map, and they can tear through unprepared raiders very quickly.
Other players may also be searching the same rooms, especially because Stella Montis is a new map with high loot interest.
Tight corridors make ambushes extremely common, so listen carefully for footsteps and ARC drones.
Move carefully, stick to cover, and avoid funneling yourself into obvious choke points. Once you reach an extraction site and call for a lift, stay alert until you're safely off the map. The right ARC Raiders Items can help you leave safely.
Breaking New Ground Event Guide - How to Unlock Stella Montis in ARC Raiders
ARC Raiders' Breaking New Ground live event arrived alongside the massive 1.2.0 update, bringing with it one of the community's most exciting collaborative goals to date: unlocking the brand-new Stella Montis map. This limited-time event encourages every player to contribute resources, earn Merits, and help the entire ARC Raiders community push the project toward completion.
Whether you're a veteran Raider or someone just loading in for the first time since Patch 1.2.0, this guide covers everything you need to know about the event-how it works, what you should contribute, and the fastest ways to rack up Merits before the event ends.
What Is the Breaking New Ground Event?
Breaking New Ground is a global community event accessible directly from the main menu. With Patch 1.2.0, players were introduced to two new Arcs, new reward tracks, and-most importantly-a community-driven construction project that, once completed, unlocks the upcoming Stella Montis region.
Instead of simply waiting for the new map to arrive in a future patch, ARC Raiders puts its players in the driver's seat. Every donation, no matter how small, moves the progress bar closer to unlocking Stella Montis for everyone. It's a collective push toward new territories, tougher encounters, and fresh rewards.
The event is only available for a limited period, so it's worth checking in whenever you log on. As long as the Breaking New Ground icon appears at the top-left corner of the main menu, you can enter the event page and contribute.
How to Participate
Getting involved is extremely simple:
Open the game menu.
Locate the Breaking New Ground event icon in the upper left corner of the screen.
Click it to enter the event interface.
Inside the event menu, you'll see the community progress, the material donation panel, and how many Merits you've earned so far. From here, you can repeatedly donate materials in order to help fund the construction project tied to cheap ARC Raiders Coins Stella Montis.
  • Körteknik »
679 gäster, 1 användare (0 dolda)
larryberger
Flest online idag: 826. Flest online någonsin: 2678 (22 oktober 2025 kl. 22:20:07)
    2 maj 2023 kl. 10:33:51
    13 april 2023 kl. 18:49:39
    12 april 2023 kl. 11:21:26
