Allmän diskussion
Tester och Recensioner
(Moderator:
ELD.gg Path of Exile 2: Tactical Summoning: The Witch’s Advantage
Ämne: ELD.gg Path of Exile 2: Tactical Summoning: The Witch’s Advantage (läst 10372 gånger)
Lilidala
Antal inlägg: 3
ATV eller Fyrhjuling?
Lilidala
14 april 2025 kl. 08:00:03 »
Misunderstanding 1: Blindly stack the number of
POE2 Currency
minions.
→ Correction: More than 6 minions will trigger "soul overload" (they will suffer additional damage), so the number needs to be controlled.
Misconception 2: Ignore the main body's position.
→ Correction: Although the witch relies on the minions, she still needs to maintain a "triangle position" (at an angle with the minions and the enemy).
Advanced skills:
Hate transfer: Using "Provocation Potion" on the minions can force the enemy to attack it for 3 seconds.
Environmental utilization: Lead the enemy to terrain such as "poison swamp" and "magma", and the minions will block the road to achieve continuous consumption.
Summary
The essence of the witch is a battlefield commander, who needs to coordinate the three elements of minions, spells, and
buy Path of Exile 2 Currency
environment. Master the rhythm of "retreat to advance", and you can counter through strategy even if your equipment is inferior. Remember: your survival is the guarantee of victory, let the minions become your shield and sword!
Allmän diskussion
(Moderator:
1399 gäster, 0 användare (0 dolda)
1409
