Suzuki
back varvstoppet
Ämne: back varvstoppet (läst 2488 gånger)
zupe
ATV Extreme
Antal inlägg: 685
zupe
back varvstoppet
27 oktober 2007 kl. 21:14:56 »
Hur kopplar man bort det?
Grymmt störande.
Gäller en ltz -06
Can am outlander 1000 xtp -18
Suzuki LTZ 400 -06 gul
Visby
Norlin
Antal inlägg: 45
Norlin
back varvstoppet
28 oktober 2007 kl. 10:27:17 »
håller med.. blir som irriterad varje gång!
Sportsman 800 efi -07
PB 818r -0?
LT-Z 400 "såld"
Mxz 550x -07 "såld"
zupe
ATV Extreme
Antal inlägg: 685
zupe
back varvstoppet
3 november 2007 kl. 23:37:05 »
ingen som vet?
Måste man byta cdi box eller kan man koppla om det själv på något sätt?
Visby
svensson
Antal inlägg: 75
Can-Am DS450 xmx
svensson
back varvstoppet
4 november 2007 kl. 10:26:55 »
Jag följde denna quide som jag hittade på z400central.com
Disable Reverse rev Limiter
All Indicator lights will work like normal.
Unplug the CDI connector
As you look at the connector with the lock at the top, take a small screwdriver slide it in above the pin you want to remove the pull the wire. I took me a while to figure it out, you wont have to pull hard it should slide right out.
1) disconnect the black wire with the red trace and the blue wire with the black trace and put a piece of shrink tube over each one of them and put a dab of silicone in the holes they came out of.
2)pull out the black wire with the brown trace and the black wire with the white trace. Keep track of the hole they came out of. Make a small jumper wire (about 28 ga.) about 2 inches long, slide it under the rubber seal on the black/brown wire connector pin and solder it to the pin. Do the same to the other end of the jumper and solder it to the black/white wire connector pin. Now put these two pins back in there respective holes. put a dab of silicone between the jumper wire and the wire next to it.
the rev limiter will be set the same in reverse as forward.
Funkar perfekt på min 07:a. Var uppmärksam på att inte förväxla svart/brun med svart/orange.
Can-Am DS450 xmx
zupe
ATV Extreme
Antal inlägg: 685
zupe
back varvstoppet
4 november 2007 kl. 11:27:32 »
En får tacka så mycket måste testas.
Visby
Suzuki
back varvstoppet
3071 gäster, 0 användare (0 dolda)
5509
