  • Dataspel »
  • Ämne: MMOEXP Warborne Above Ashes:Heals caster per enemy hit
Författare Ämne: MMOEXP Warborne Above Ashes:Heals caster per enemy hit  (läst 103 gånger)
Utloggad Damnmy
  • Antal inlägg: 3
Damnmy
« skrivet: 13 juni 2025 kl. 09:09:35 »
Warborne: Above Ashes delivers a gritty, unforgiving PvP environment where the difference between victory and defeat often comes down to the right build. In the endgame meta, the stakes are higher, the competition fiercer, and only the WAA Solarbite most optimized setups thrive. Whether you're engaging in duels, faction wars, or territory control, having a top-tier PvP build is crucial.
Here’s a breakdown of the best endgame meta PvP builds in Warborne: Above Ashes, with details on attributes, gear, skills, and playstyle.
1. Shadowblade Assassin (Dexterity / Intelligence Hybrid)
Playstyle: Stealth burst damage, mobility, high-risk/high-reward
Best For: Duels, ambushes, small skirmishes
The Shadowblade is currently a top-tier PvP build thanks to its ability to eliminate targets before they can react. Using high Dexterity for speed and critical chance, combined with Intelligence for utility spells, this build dominates one-on-one and small-group fights.
Core Attributes:
Dexterity (Primary)
Intelligence (Secondary)
Key Skills:
Phantom Step – A short-range teleport granting invulnerability frames
Blade Waltz – High-speed flurry attack dealing critical damage
Mind Snare – Interrupts casting and lowers enemy resistances
Recommended Gear:
Shadowthread Leathers – Boosts stealth and movement speed
Whisperfang Daggers – High crit, fast attack speed, applies bleed
Ring of Whispers – Reduces spell cooldowns and increases crit damage
Tips: Time your burst combo after your target uses a dodge or defensive cooldown. Excellent against squishy mages and unprepared casters.
2. Ashen Juggernaut (Strength / Faith Hybrid)
Playstyle: Heavy tank, attrition fighter, crowd control
Best For: Frontline combat, team fights
The Ashen Juggernaut can take a beating and keep going, dishing out area damage while sustaining through faith-based self-heals and buffs. It’s a meta staple in territory battles and group PvP.
Core Attributes:
Strength (Primary)
Faith (Secondary)
Key Skills:
Earthshatter Slam – AoE knockdown with high poise damage
Sanctified Bastion – Temporary shield that absorbs incoming damage
Light of Renewal – Healing aura for allies
Recommended Gear:
Molten Sentinel Plate – High poise and knockback resistance
Ashbrand Greatsword – Deals fire damage and causes burn
Sunbound Talisman – Boosts healing received and reduces divine cooldowns
Tips: Anchor your team by initiating fights and absorbing focus fire. Coordinate with healers and ranged allies for sustained engagements.
3. Necrotempest (Intelligence / Dark Magic Build)
Playstyle: Zone control, attrition, summon support
Best For: Mid-range control, sieges, crowd disruption
The Necrotempest focuses on overwhelming opponents with dark spells, summons, and AoE damage. While not tanky, it’s devastating when positioned well and supported.
Core Attributes:
Intelligence (Primary)
Optional: Faith or Dexterity for secondary utility
Key Skills:
Raise Undead – Summons skeletal warriors for damage and distraction
Void Pulse – AoE dark explosion that weakens armor
Soul Leech – Heals caster per enemy hit
Recommended Gear:
Runebound Wraps – Reduces cast time and increases AoE range
Staff of the Forgotten – Buffs summon health and spell potency
Ebon Grimoire – Adds lifesteal to WAA Solarbite for sale dark spells
Tips: Stay behind the frontlines and cast in waves. Your summons can interrupt enemy casters and soak hits. Works especially well in drawn-out PvP scenarios.
  • Dataspel »
636 gäster, 0 användare (0 dolda)
Flest online idag: 664. Flest online någonsin: 2334 ( 3 maj 2025 kl. 10:37:13)
    2 maj 2023 kl. 10:33:51
    13 april 2023 kl. 18:49:39
    12 april 2023 kl. 11:21:26
  • topo1: cectek
    12 april 2023 kl. 11:08:57
  • Jannethegamer: Smc
    1 april 2023 kl. 19:15:32
  • Högdahl: 🍻🍺
    9 mars 2023 kl. 14:10:18
